hi,
why is there no support for Jetblack whisperdrive?
its a direct drive trainer.
the new one comes with built in sensor.
the old one has a speed sensor that can be connected to it.
I am not the first one to ask this and probably not the last one
thanks
eyal
Good question Eyal. Although there is currently a speed sensor for the JetBlack WHISPERDRIVE it has not been supported in the past due to technical limitations around it’s design, and there are no current plans to integrate it into the system. So even if you did connect a speed sensor, you would not get an accurate reading. As you said there are new versions, such as the JetBlack WhisperDrive Smart which are supported. We’d love to see you out riding with us so if you want a reference on which trainers are compatible, check out our article here!
