First make sure nothing else is paired to your NGeco. Turn off any head units. Close out any other apps. Etc… On the pairing screen, pair the power source (p2max) first. Remain on the pairing screen and start pedaling. You should see watts go up. Assuming that works, pair the cadence. Pedal again and you should see both cadence and power go up. All good? Still not working?
