Ipad HDMI connection
Anyone have a clue why my Ipad to tv connection stoped working? Im using an Ipad Pro with an hdmi adaptor fro.t the lighting port to an hdmi input on my tv? It work great for the last 4 years but seem to stop working after the last Ipad up date. I get an error message that the adaptor is using to much power.
Tjanks for any help.
Is the HDMI adapter plugged into a charger when this happens? Is the charger a 2 amp variety? Is the HDMI adapter manufactured by Apple or is it a third party model?
I don’t think this is a Zwift problem, but you may be able to resolve it by making sure that there is enough power provided. I’ve also heard of many people using third party adapters that stopped working after updating to iOS/iPadOS 18
Thank you for the fast reply. I tried two different ipad pros and neither one works after the update. I can use an older ipad that will work with the cables and tv but cant be updated to run Zwift. Im not sure if the adaptor is an actual Apple one but ill buy one to see if it makes a difference. The adaptor does have a power supply and I have changed hdmi cable and port on the tv.
Thanks for Apple adapter idea.
Also make sure the power supply you are using is designed for a tablet. Do not use a 1 amp charger designed for a phone.
Thank you Paul…The power supply is a 2.4 amp from Apple. I have been using this same setup for the last 4 years. Im going to pick up an Apple name brand adapter and try it.
Rich
Thanks Paul…i picked up an Apple HDIM adapter and it works great…peoblem solved.
