Introducing Zwift Companion Fitness Tracker [April 2025]
I made the weekly goal something completely unrealistic ( for me, anyway ), like 6000 miles.
That way it won’t pop a banner in game while I’m riding.
I think I will disconnect Zwift from Garmin to avoid this.
Hello Zwift, The new fitness panel occupies half the real estate of the Home screen on iOS. I request a way to move or remove it. Thank you!
This is a reasonable request - put another icon up near the notification icon to toggle the fitness history visibility.
Hi. Can you record your outdoor rides using Strava, or must I buy a garmen. And in that case do you need power meters as well. All a lot of expense
At this time it only works with Wahoo and Garmin, you don’t need a power meter for outdoor rides to count.
Are the cycling stats in your profile just the miles done on zwift?
I don’t want those to include other activities, I like knowing my all time mileage and stuff just for zwift rides and would like that to be kept separate.
If not I’ll have to disconnect Garmin from my account.
You don’t need to trash the activity, zwift won’t save activities under 2kms, and saving it won’t affect the spot in the pen when you go back
Good point
Technically speaking, you can record outdoor rides using just Strava. But for them to be included in your Zwift totals they have to be recorded with a Garmin or Wahoo device.
It should certainly be compatible. My Edge 840 rides are showing up in Zwift.
You have to connect through the companion app, did you connect to garmin in the companion app?
Hi Nigel.
Thanks. This time of year when weather is nice I ride to work. 25 miles each way. Be good to have that counted on Zwift. Strava I was hoping that would be a simple answer.
Wondering if anyone is in a similar situation.. Since I switched from a Garmin device to a Pixel watch I only sync over my activities from Strava to Garmin to also have them there as well. So I was wondering if I could use this for the Zwift streaks as well but it looks like as if Garmin is not syncing over bike ride activities into Zwift that were not recorded with a Garmin device. Or did anyone manage to get this to work? Would be great to get my outdoor rides into Zwift. :slight_smile:
This update has added a Fitness Tracker to the Zwift Companion app, which I do not need. How do I turn it off?
At minimum, if this thing that I do not use, must occupy real estate at the top of the Zwift Companion app; then how do I remove / delete / unset this weekly goal that I did not create? There is now a 3 hour weekly goal that I did not create and the instructions at Managing Your Goals don’t work. There is no Remove button and in general the instructions appear to refer to the old version of the app.
How do I delete this goal?
Click/touch the goal area and you can edit them, make it 50 hours if you never want to see the pop up banner in game.
Hopefully they give us an option to opt out of this feature in the future as it is quite useless to most athletes who use a number of other programs that give better and meaningful data.
Accurate description of what needs to happen but for now you live with it
Editing the goal to something unrealistic is not the same as removing the goal entirely. Thanks for the suggestion but this is not what I am looking for. I want to delete this goal, with vengeance.
If you figure out how to delete goals please share the process
It seems that Zwift unilaterally forced a 3 hour goal on me. I’m still waiting on instructions on how to delete it.
