would be very nice to have your IT opinion on the following issue:
here old school zwifter, level 47 and 22000kms done,difficult level always at 100%
i’m zwifting now on a phone screen Xiaomi 11Pro T 6,67" screen on landscape mode,Trainer is Wahoo Kickr V.5 the latest model, Xiaomi has an Octa Core 3mghz processor with 8GB Ram
on the Xiaomi Zwift runs very very smoothly, with Sim mode working perfectly, -5% feels really like -5% and +5% is hard as it must be
but when i Zwift on a Asus pc which has I3 core with 8GB ram and clock up to 3ghz,
everything feels totally different,not smoothly at all and even +1% feels like +3% or +4%, there is no flowing at all everything feels like forcing the pedal stroke
i have had before an HP EliteBook with I7 core and all felt very ok
could this be because I3 Core is not enough to fully handle Zwift and it would require I7 or even higher???
if you would be kind of enough to post your opinions,that would very kind
Totally depends what exact model of i3 it is; 3.0GHz suggests old/weak/mobile. Just going to ‘an i7’ doesn’t mean anything, again it depends on the model.
For reference, most desktop 4th generation i3 CPUs can provide a very similar experience to Apple TV 4K in terms of graphics and frame rate/perceived smoothness. They are readily available for £8 in the UK.
So that should be fine in terms of performance, but it’s worth noting that there are stability issues with Zwift on 10th and 11th gen integrated graphics. There’s a couple of long threads discussing it on this forum. It’s possible to work around the problem on Windows 10, but not Windows 11.
That aside, make sure the PC is in high power/performance modes and plugged into the mains (assuming it’s a laptop).
thanks your support,what i have been reading on the i3-1115G4 is that is a lower-middle range cpu suitable for day-day tasks but not
good enough for high end games like Zwift,the main issue i find when zwifting with it compared with the Octa-Quore on my 6,67" screen Xiaomi is the smoothness, the game runs perfectly fine on the Xiaomi but not on the pc where is constantly the feeling on sim mode that even +1% feels like +5%,the road feeling with the i3 is quite none.
thanks your mail,
the Kickr is the latest version
V5… don’t exactly know the Bluetooth version on the Asus but it should be the latest Intel Ble version
on the Xiaomi it has Ble 5.2 or even
higher and with the phone it works perfectly,with the Asus Zwift works totally ok,only there is no flowing or smoothness on the pedaling
the sim mode is constantly very hard
even at +1% but on the Xiaomi sim is exactly as it shows
just rechecked the situation and indeed is an ble connection issue
when using the Xiaomi, like moments ago, by opening the Android Zwift app
the Kickr is fully connected and on the
power, cad and controllable boxes besides the Kickr serial number and the ble icon u can see the green signal bars how strong the ble connection is
i use as well Garmin Fenix 6Pro in Virtual mode so that transmits the HR
directly from the wrist to Zwift,which works totally,and in the heart rate Zwift box u can see the green bars how strong ble is
but when using the Asus pc,the Kickr reads connected and the ble icon is there but there are not the green bars
that means the Kickr is not full connected
on the pc Zwift heart rate box the garmin is connected and u can see the green bars
so what could be the solution for the asus pc?? and exterior Bluetooth connection via usb to the pc like ble 5.1,they cost about 20e
or an ant+ dongle which i’am afraid could be the best solution
I am using Bluetooth with my PC setup and have no problems. It actually works better for me (reacts faster etc…) than ANT+ which I have used before.
But I may seem lucky, because I heard many horrorstorys regarding the failure of using BLE and Windows.
The CPUs mentioned are with reference to performance of Zwift as a 3D video game, not connection reliability to your trainer etc. They’re completely unrelated.
the main issue seems to be that i just can’t connect the Kickr to my asus pc via bt… asus is running win 11 and for what i have been reading a lot of people are having the same problem.
