I got the ant+ but still not pairing, it keep searching but nothing happens
Ingrid, how far away is your computer ANT stick from the trainer? Many people here need a extender to get them fairly close together
ingrid are you using the in ride option?
Do you have an ant+ stick?
David,
Is next to it, I got the extender
Matt-I have the inride app but not sure how to use the inride option with zwift. Thanks!
Ingrid, then you don’t use the ant+
The Kinetic InRide uses Bluetooth, so you will need to set your iOS/andrioid device to use the Zwift Mobile Link to act as a Bluetooth bridge between your InRide pod and Zwift.
For instructions on how to do so, please visit our Knowledge Base article here: https://support.zwift.com/hc/en-us/articles/206576683-Bluetooth-LE-BLE-Support-for-HR-Monitors-and-Power-Meters
That should help you here set up!
Matt you are the best! thank you for your help. I’ll follow your instructions. Thanks again ![]()
Ingrid did that work out for you?
No it did not. I I have tried everything. I’m giving up ![]()
Ingrid,
see below there are some additional information.
https://support.zwift.com/hc/en-us/community/posts/203945453-INRIDE-POWERMETER
Matt, I finally got it to work! thanks for your help. I deleted the app from my iphone and computer and then installed again and voila! Thanks again!
