Somehow my zwift connection page on Apple tv went from “Pair with Bluetooth” to "Pair with Phone. I must have hit the wrong button somewhere. Can’t seem to change it back with ATv remote. Suggestions?
Hi @Irish_Pedaler Welcome back to the Forums! I’m Norman from Zwift. You must be referring to this button right?
This button’s function is to enable the pairing through a Zwift Companion App bridge, you can check this article for more information.
At the moment you’re able to pair your equipment directly through Bluetooth, but if you want to “Pair Through Phone”, you can just tap that same button and be able to open a bridge through the Zwift Companion App.
Thanks Norman. That is the screen I was referring to. The problem is that I want to switch back to" pair with bluetooth". Not seeing how to do that on atv.
I think you just click the blue box. It should switch to the other?
Thanks for the replies. Finally got it switched.
