How Do I create event in reverse In the Zwift companion app?
Thank you ![]()
Thank you ![]()
You mean to create a Meetup or a Club Event?
You can only pick from the existing Zwift routes. There are reverse versions of a few routes, but there’s no way to select a reverse version if Zwift hasn’t already created one.
That brings to mind a question (only slightly off topic) … if you are riding a set route and do a U-turn, do you then follow your selected route in reverse?
you can’t do a U-turn in an event. But on a free ride yes you will follow the route in reverse.
