Seems that once you select a workout or a ride, you have to stay with that. If you want to select a new workout, you have to end ride or discard, both of which disconnect me from Zwift. I then have to go back to my applications and set everything up again.
The menu doesn’t offer a way to start a workout and then do another one during one ride. Is this the only way?
Hi Deborah, if you are on a Mac or PC, you can use the ‘E’ key to bring up the workout selection screen. This could be helpful if wanting to go from a normal ride to a workout. I’m not sure of a way to do this on iOS or tvOS.
E works-yes. However, I clicked on the wrong ride and when I hit E it put me into a loop back to menu. I couldn’t get to the page where you could select the rides from the right side of the page. So I had to end ride, and set Zwift up all over again including re-pairing etc. Needless to say, I got to the ride quite late.
This is what I’m trying to figure out how to do. If I start a group ride, and want to switch to another, I can’t seem to get to that without starting completely over.
