Hold key to navigate
Navigating through long lists on PC can be quite tiresome as you have to press a key for each item in the list. For instance, moving down the route list on Watopia can be many key presses. It would be great if you could press and hold to scroll through the list. This would also be good on the home screen, scrolling sideways on the Robopacer list. Bonus points if the Page Up and Down keys jumped multiple items at a time, and the Home and End keys jumped to the top and bottom of the list.
It would also be cool if the press and hold worked on the Play controllers, too. At the moment, navigating lists with those is basically the same as using the cursor keys; requires a press for each item in a list.
