Help with bluetooth connection to Cyclops trainer
Hello, I was using Zwift with a Cyclops/Saris trainer a friend gave me, and using Ant+ on my laptop everything worked fine. The Zwift app sensed it as Cyclops 2432. When I tried to connect my phone via bluetooth (because using the laptop is cumbersome) it could read the speed sensor, for which I had to enter unknown trainer, and the Cadence, which is Wahoo, but for power source, it did not let me connect anything and the rider does not move.
Any suggestions about how to fix this (if it can be fixed) would be most welcome. Thank you.
It’s likely that the trainer is too old to support Bluetooth. You could try scanning for it using the nrfconnect app, but if it doesn’t show up, that’s probably the answer. That means use the laptop or replace the trainer with something more modern.
