Going off course on group rides
I want basic comprehension on this point:
“When in an event, regardless of a route selected, all event riders should be grouped together regardless of the event route selected. They should be able to follow the same path until the time-based event is complete. This should even apply to riders even if they late join.”
It shouldn’t be so hard to algorithmically determine a breadcrumb trail or some type of pointer system to ensure riders do not “split”.
I don’t know why this is so hard to comprehend.
Going back and forth on this is useless.
Either Zwift can develop well, or not. Their choice.
Unfortunately even with basic circuit routes we still have instances of folks going off path.
Pathing has proven to be a continuous nightmare, so unfortunately I wouldn’t expect a fix for this for years to come; seeing as how it is an issue basically a decade later.
Regardless; the primary solution to this problem is to inform ride leaders to not choose non-looping routes.
My assumption is that there is some kind of random number generator used to determine which way you go at an intersection when you’re no longer on a route. In an event, a reasonable fix would be to make a single random choice apply to everyone in the event rather than calculating it for each rider. The choice of the first rider through the intersection should apply to all. It’s not really a problem with the route design.
Or there’s literally nothing in place to make that decision at all; which is probably a more likely scenario.
Personally; I like on that new route getting split and others; we turn them into opportunities.
We don’t see it as a negative, but a fun option… (But we also know what we’re getting into ahead of time so there’s that)
I’m not a programmer, but there has to be something that is determining the decision, if there’s a decision being made, right? If a rider gets to a ‘choice’ of L or R, and the rider goes R, then something in the programming determined that. Whether it’s a ‘random’ number gen or it’s some other bit of code somewhere. If nothing determined it, then nothing would have happened–they’d have just stopped :slight_smile:
It might be that there has been nothing put in place on purpose to make this decision–it’s defaulting to something that wasn’t intentional but is considered to be ‘good enough’. Maybe in creating the code they said “Given the code we developed, I wonder which way the rider will go at that intersection? We didn’t plan for that, so let’s wait and see.” But something is still making the decision.
Not that it’s this simple anymore, but something like an IF In_Event AND Route_Complete THEN Turn_Right could do it, no? :smiley:
I have no idea; but I feel like if something were there we would indeed all go the same route, but we don’t.
Does that also make sense?
Seems more weird that a rand would be a deciding factor. Perhaps it’s also the fact that it usually spits us out into a looping circuit as well, and that’s just what it sticks to; I don’t think groups would get split into 3… I don’t know, all of it is just weird cooky things about programming I’ll never wrap my head around I think haha
Also I feel like if there was something there, folks wouldn’t take wrong turns on group rides anyway (like mid-ride as we had experienced a lot of through spring/summer this year)
It’s a weird one for sure either way.
Oh well…
I do think a lot of this is all very ingrained in Zwift’s code too; otherwise, why wouldn’t we have “open roam” for group rides where the leader could decide which path to go down at all? (maybe one day… meanwhile I can keep dreaming about that)
My guess would be that at the moment there’s some determiner that is 1) effectively random and 2) individually determined for each rider. By effectively random, I just mean that the rider doesn’t know which one it’s going to be–maybe there is some set factor. In the same way that your appearance at the beginning of a free ride route is not exactly one spot–they space people out over a length of road so everyone’s not sitting right on top of one another. Maybe things like ‘turns after the route is over’ are determined at the same time.
But it seems possible on the surface to have that determined differently if one starts a group ride.
The individual riders taking wrong turns from group rides, from pacer groups, etc could be the same issue, or could be a separate bug. This case in this thread seems to have a specific and identifiable cause–being in a group ride that goes past the end of a non-looped route. That’s different from joining a pace group and then being the only one who goes left when the group goes right. But they could be related in some way.
We had the same issue this morning
Two long meetups on Coast Crusher and Canopies and Coastlines were interrupted as the group entered the Jungle Loop area. The leader (me) went one direction (left), the other riders went right. Meetup continued despite being separated. In both rides re-entry to the coastal area was blocked (green barrier), despite having several laps planned. The barrier at the Jungle Loop entrance from the Coastal area is new…don’t understand why it’s there, or why it would affect a group meetup of riders Level 50 and above.
Any other groups experiencing this situation?
This is not a bug. Those routes are not loops so when you hit the end of the route (if set for time instead of the exact distance of the route) at the next intersection Zwift sends people randomly.
If you want to do a route multiple times you need to select a looped route
I can see how Canopies and Costlines could cause issues. Coast Crusher is out and back. We did it last week and looped back to coastal area eventually. What was odd is having a banded group split up once we entered Jungle loop area. In addition, none of us remembered a green barrier between jungle and coastal re-entry.
Obvious solution is to use one of the looped rides (e.g., The Big Ring). We were combining Z2 long ride with badge hunting.
On a banded meetup? Seems odd
Yes it’s an out and back (ie there is a turnaround at one end of the route only) so when you hit the finish line there is no turnaround to stay on course unless you manually do it (which IIRC isn’t an option for a meetup). Therefore Zwift behaved exactly as it always has, you finished the predefined route but still had time left so at that point intersections become “wild cards” for riders and they get sent different ways
You are correct. The Southern Coast routes are now level-locked with the latest update, just like the AdZ and Jungle.
Thanks for the reply. I belive the lowest participant was level 49. I didn’t even t get the option (Level 60) to re-enter.
Jim Peyton
@Jim_Peyton_TFC_Phant please remove your personal information from your comment above.
Also: the level lock for the Southern Coast routes is much lower than that, so everyone on the ride should have been able to ride through the green ‘gate’, even after the meetup ended. It may have required some manual turns, though, since the route you were using was point-to-point and, as noted previously, riders will make random turns at intersections when not on a looping route.
I’m posting this issue again as it was closed without an adequate response. This issue is serious as it happed more than once.
Two long meetups on Coast Crusher and Canopies and Coastlines were interrupted as the group entered the Jungle Loop area. The leader went one direction (left), the other riders went right. Meetup continued despite being separated. In both rides re-entry to the coastal area was blocked (green barrier), despite having several laps planned. The barrier at the Jungle Loop entrance from the Coastal area is new…don’t understand why it’s there, or why it would affect a group meetup of riders Level 50 and above.
It will happen on any route that isn’t a loop during a timed event. If you want to avoid it, make sure you are selecting routes that are loops only (or long enough that you won’t reach the end of the route before the time limit).
The basic issue is that these routes are not loops. So, if the meetup is longer than the time/distance it takes to complete the route riders will go In random directions at subsequent intersections.
As for the green gates, those are new with the latest update. If the rider is a high enough level (and 49 would certainly be high enough), then the rider should be able to ride through the barrier (just like at the entrance to the Alpe and at the other end of the Jungle Loop), though they may have to select that direction manually (again, because the chosen route has ended, and everyone is, effectively, now on a free ride).
