Garmin Never Stop Cycling stage 1 - system crashed when I crossed the line
Good evening,
I was taking part in this event at 17:15 CET, and when I crossed the line and the standings were loading my system crashed and now I can’t see the event finished in my profile and I did not get the kit either.
If I enter my profile there is an activity that is kind of broken, if you try to get the detail for this one, the web gets stuck and the information never shows up
I can see these in the logs just in case it helps
[18:03:20] Route Completed
[18:03:20] GroupEvents: Completed by laps for group "Garmin Never Stop Cycling // Stage 1  - Road", subgroup "Garmin Never Stop Cycling // Stage 1 Road - Open Category", start time 11/10/2020 05:15 PM
[18:03:20] GAME_FinishedGroupEvent: seconds = 2685.485107, late join = NO
[18:03:20] GroupEvents::RecordFinish() resultTimeInSeconds = 2685.485107
[18:03:20] LEADERBOARDS: Saving segment results for segment 1 with a time of 191011504.00
[18:03:20] Broadcasting PR for segment 1 with time 2685.49
[18:03:20] Loading WAD file 'assets/UI/WhiteOrangeTheme/JerseyIcons/JerseyIcons.wad' with file.
[18:03:20] Race Result Info - GroupEvent: EventID: 1178348, SubGroupID 1512363
[18:03:20] Got Notable Moment: FINISHED EVENT
[18:03:20] GroupEvents: Wrapup (event going dormant now) for group "Garmin Never Stop Cycling // Stage 1  - Road", subgroup "Garmin Never Stop Cycling // Stage 1 Road - Open Category", start time 11/10/2020 05:15 PM
[18:03:20] STEERING : Setting Steering Available: TRUE
[18:03:20] Success: Physics values returned to normal after group event.
[18:03:21] FE-C SIM GRADE 0.000
[18:03:21] ANT  : Transfer Completed.
[18:03:21] ANT  : FET grade set successfully
[18:03:21] ANT  : Rx Fail on channel 1
[18:03:21] ANT  : Rx Fail on channel 2
[18:03:22] FE-C SIM GRADE 0.000
[18:03:22] ANT  : Rx Fail on channel 1
[18:03:22] ANT  : Transfer Failed.
[18:03:22] ANT  : ----------------------
[18:03:22] ANT  : FET Transmission failed. m_CurrentMode = 4
[18:03:22] Chat: Damb 359275 (World): Hi from Paris
[18:03:23] FE-C SIM GRADE 0.000
[18:03:23] FE-C 17 received
[18:03:23] ANT  : Transfer Completed.
[18:03:23] ANT  : FET grade set successfully
[18:03:23] ANT  : Rx Fail on channel 1
[18:03:23] NETCLIENT:[INFO] World clock offset updated from -51558498ms to -51558499ms (-1ms)
[18:03:24] FE-C SIM GRADE 0.000
[18:03:24] ANT  : Transfer Completed.
[18:03:24] ANT  : FET grade set successfully
[18:03:24] Starting critical power curve search job (1981330535)  mTimeStamp = 3242.14111  m_lastSearchTime = 3242.14111   calculating=false
[18:03:24] ANT  : Rx Fail on channel 1
[18:03:24] ANT  : Rx Fail on channel 2
[18:03:25] 1707274: [pos: 213] [finished: ] [duration: 2685] [w/kg: 0.000000]
[18:03:25] CrashHandler: Dump Request Failed
Same happened to me at 22.15 CET.
