I have a problem when Zwift send the Activity to Garmin Connect … Everyrthing ok except for the km which dosen’t count in the monthly challenges…thank in Advance
welcome to the forum.
That sound like Garmin connect does not take virtual rides in to account.
Garmin takes virtual rides into account but the activity has to be recorded on a Garmin. I get around this by exporting the fit file from Garmin Connect into www fitfiletools.com, changing the device to a Garmin, and then importing it back to Connect
Thank you…It work ![]()
It does, for some totals and few metrics, but Garmin Challenges are to be recorded on a Garmin device. That’s why there is the need to always modifiy a fit file or double record or merge fit files…
As I wrote above, using fitfiletools to change the device type to a Garmin WILL generate data for the challenges.
Yes that’s why I wrote the need to always modify a fit file or double record or merge
I wasn’t contradicting you…
I personnally prefer to merge files so I get the Zwift distance and elevation into the Garmin fit file with the rest of the ride activity data…
