Game Update v 1.96 [August 2025]
is there an option to enter a TT club racing without being in the club? Or it’s a club-team racing only?
Anyone can join those events
Version 1.96 is available to all devices
Anyone else having the issue of the magic disappearing cursor in w11? makes navigating almost impossible
Did the pas de puyol/muy Mary climb and on the way down the left hand board showed the grade climb rather than what climb I’d just done
It becomes an Easter egg and not an achievement. :woozy_face:
Speaking of Android, Companion app version 3.73 isn’t showing as available from Google Play on my device. Has it been released to them?
The latest version of Zwift Companion is 3.73.2 3.73.3 (edit: fixed typo) which was rolled out to 100% availability as of Tuesday Aug 26.
In Zwift Companion, if you go to Menu –> Settings –> About, what version do you see?
And if you navigate directly to the Zwift Companion app listing in Google Play, do you see any available updates pending?
Thanks for reporting this - is this happening intermittently, or in every Zwift session?
Thanks for the report - I’ve raised this to the team.
I’m on Android and currently in North America.
I received the update and am on 3.73.2 (2134)
I was seeing 3.72.2 and I saw no pending updates and I check twice a day as I have other updates pending as well that haven’t appeared on Google Play.
Update: 8/23/2025, I checked the app today and am on 3.73.2. Will check for the Home/Map function as I didn’t see it ony initial report
You mean 3.73.2, right?
I tried multiple times to close down swift and restart and the problem persisted but didn’t have time to mess around so just skipped my ride will have to retry tonight.
screenshot showing it
Why is it that most everytme 'Zwift Does an update my system has issues. This time it stops then starts then stops continuously? Gets rather annoying.
What starts and stops continuously?
There don’t seem to be general stability problems with this release but if you want to share detailed information about what you are running the game on, perhaps you will get some suggestions.
Got it in downtown watopia as well. It’s zwift, isn’t it?
Ah yep, typo, thanks for the catch! Edited above. 3.73.2 is the latest version of Zwift Companion for Android.
Any updates on running and being able to set goals? Also when will running outdoors count towards virtual runs similar to biking? I keep asking but no response.
