there are 32GB of RAM…
I just cannot believe that this issue is hardware (perofrmance) related, cause it worked before update to 1.77 without any issue…
Taskmanamger shows enough free resources, although Zwift requires a lot more since 1.77…
Hi Zwifters!
Please note AppleTV rollout has begun today. All other platforms should be complete.
Keep in mind that Zwift mostly loads a single CPU core so a Ryzen with a lot of cores may appear underutilized when you have maxed out one core.
I updated to version 1.77 this morning. Since then, I am having problems maintaining connection to my devices through ANT+. I can pair my devices initially, but if I stop for more than a minute, connection is lost. The pairing screen says “no data”, when I try to find the devices, I can’t find or pair them.
Sensors that aren’t “interrupted” (e.g. heart rate monitor), those signals are still received fine.
I have been using Zwift since Beta, haven’t had ANT+ connection problems before this update for years, so fairly confident it’s not my setup.
Zwift support just told me to update my ANT+ USB driver, but I was already on the latest version, 1.2.40.201, for Win10.
Received the update yesterday; on a group ride in Makuri Island’s Farmland Loop, around the main start/finish arch in Makuri, was experience MASSIVE frame drops and CPU spikes through the roof.
I know this issue seems to come and go, but it was markedly worse than I’ve ever experienced before.
Attached is an image of the area I experienced total frame drops; each lap. This wasn’t even with a large group, under 60 riders.
Here this issue was related to the windows drivers.
Used the drivers provided by MS for some time now, cause it just works these days.
But with this issue, installed the curent AMD driver pack → issue gone…
So - sorry for wasting time here.
Returning a ride on using the play controllers doesn’t work for me either, only the ride on bomb works. I’m using Windows.
Same issue with a Ryzen7 mini-desktop machine with 1.77. Updating the drivers from AMD brought me up from 5fps back to 25fps that I was used to.
Runners can now open the Pairing screen and continue running in-game at the same time
This was a bad thing!!
This i use my ‘’A’’ key to stop my avatar running while have the treadmill keep gooing for breaktime in my intervalls!
Is it another key that can be used for that thing?
Break time during intervals, you want the treadmill to keep going so you can still gain distance while you stand on the sides?
Marcel!
Good thing are worse waiting for ![]()
So you just have to be patient.
Always look on the bright side of life…
Cheers, mate
The font size has not increased at all…
I (as I’m sure many other laptop screen,or smaller, users) was really pleased to read this and anticipated some improvement.
However, (running MacOS on a 13” display) I can report the font sizes of the metrics in the left side HUD have remained identical to pre-1.77. No change whatsoever, not 1 pixel taller/larger.
I still puzzle why the units were moved to underneath the numbers which enforced this shrinking in size and visual clutter which also makes them harder to read.
In a race this morning I would get notification of “____ is now riding in Paris” every couple minutes, it wasn’t at the start just seemingly random intervals through the race, and got 3+ notifications for each friend.
I also experienced the loss of holoreplay ghosts in nearby riders list. Also noticed that after I completed a ride and started a new one, my companion app disconnected like as if Zwift wasn’t running, yet my Zwift play controllers and sterzo continued to work throughout the next ride even though the companion app appeared to never reconnect. Finally, it was mentioned that the return-a-ride-on via Zwift play would still work even though there was no notification, after some testing, this is definitely not the case. I find that to be my most used feature of Zwift play, so please please give that back to us.
2 posts were merged into an existing topic: New Garmin Synching issues
it still works, but the visual message to press Z to return a ride-on has gone missing, it is a known issue already.
If that were true, I’d be seeing the thumb and fireworks when the rider is close by, and I don’t unless something changed in latest update
The companion app issue hasn’t happened today FYI
Another ride with Kickr Shift gears stuck on displaying gear 8.
Hi folks -
Our team is looking into the issue with activities synching to Garmin. Please join us on this thread - New Garmin Synching issues - for discussion and updates.
