Have they perhaps given you a ride on during the activity, rather than seeing the activity on Companion app once saved?
No. I got the ride on notification on my phone 30+ minutes after I was done riding
I have something weird since this last update, and I wonder if anyone else had the same issue.
After a while (like 30-40 minutes), my left Zwift Play controller starts to steer to the left, and keeps steering left. When I turn it off and on again, the issue is fixed until it reemerges. Anyone else had that same issue ?
Many people have had that problem when the Play controllers start to fail. If you contact support you could talk about the possibility of replacement. They will probably start by recommending that you do a hard reset by holding down the big Z buttons for 30+ seconds, make sure the firmware on them is up to date, and possibly calibrate them.
Not sure which update, but has to have been least last couple. The steering on my controllers has been WAYYYYYYYYYYYY to sensitive. With just the smallest touch to steering you end up all over the road,.. I have also noticed this in a few rides from others as well.
Happy New Year, Zwifters!
Everyone please update at your earliest convenience.
Had an issue where 10mins in, hrm dropped out just as the resistance in a workout ramped up, on attempting to reconnect it zwift app became sluggish and frame rate dropped significantly. Retried 3 times after including after restart but refused to connect, sliggishness persisted. Had to abandon session.
What are you running Zwift on, anything going on in the background?
Xeon E3-1275+GTX960 - Usual bg video playing with BT headset for audio.
Direto paired via BT, Click v2 paired via BT, HRM via Ant+
rest of system was responding normally, just zwift had gone sluggish
Your description reminds me of a problem that has been coming up occasionally for a while that causes Zwift to lose its mind when an ANT+ adapter is present. Some discussion about it here:
Thank you, that’s pretty much bang on, I’ll try the steps in the linked thread.
Thanks Zwift for the progress report screen. It includes lots of useful information, however, a lot of the information is most useful when observed over time; how did my training score change this year, how did my racing score change this season? Could we please have the facility to interrogate these metrics on a timeline so that we can see how we evolve during training prgrammes, injury recovery etc.
Have you looked at the trends available in the Companion app?
Personally I use intervals.icu for that kind of analysis, but the Companion app has something if you tap on Fitness Trends.
With the latest 1.104.4 Release, I am having a Resistance issue.
I did not encounter the issue with previous 1.104 releases, so I don’t know if this is the same issue or not, but I definitely rode the previous releases.
I have tried to use the Zwift Companion bridge as a workaround and it does not work.
Windows PC, Wahoo Kickr Core, issue started on Tuesday, 1/6, and it looks like that is when my Zwift was updated.
I can ride Workouts with ERG mode on, and everything is normal.
In other modes, shifting into what should be higher gears, I am still spinning out with very little resistance, less than 100W in the biggest gear, spinning at 100 RPM.
I used the Wahoo app, and it has no issues with resistance.
For weird steering issues, you can do a hard reset of your Zwift Playcontroller.
Hold down both of the power buttons for about 30 seconds during which it will power down and reset itself. Release both buttons after 30 seconds and it should power up itself again. Try reconnecting the Play controllers and ride.
I have the Ride and it did happen to me before. I did this and it went away.
The title of this thread did not change to reflect that this is a Jan 2026 update.
@shooj I have asked similar questions before and got nowhere. Asking again.
Why is there so much inconsistency with Zwift unlocks with what can and cannot be equipped on both Running and Cycling Avatars?
I unlocked the Tour de Zwift 2026 Party Cap which matches the Tour de Zwift 2026 Run Kit well, yet it cannot be equipped while running, however last year’s Tour de Zwift 2025 headwear and also Confetti Socks and several other things unlocked while cycling CAN be used on running avatars.
Can you please make this year’s Tour de Zwift 2026 Party Cap equippable for running? Please check into the other items that can be eligible also, it makes sense for people who cycle to carry over their swag to running, especially while running with runners who do not cycle.
Confetti socks while running? I need that!
Running with the lightning aero socks would be fun too. Almost there, went over the 800 mark tonight.
