Game Update - October 22nd, 2020
On the first ride after installing this update, three times my avatar stopped pedaling although I kept moving and all parameters ok. I discovered that if I switch to higher gear / lower RPM to cause my avatar to stand, fixed this (untill next time). Never had this issue before
You broke Bluetooth on Windows 10… Again!
Every time an update is installed - Bluetooth on Windows 10 breaks. I have to literally restart everything. Native apps work with Bluetooth without issues, but Zwift fails to connect to more than 2 endpoints.
Do you not pay your testers enough?
Hi Zwift Team,
I Waste hit by a bug toddy in a race on Watopia Flat. The resistance didn’t increase at the small hill on the way out of the tunnel. It was like 0 degree rise, when I was cycling on the small hill.
Regards
Henrik
Why don’t the patchnotes mention the Canyon Aeroad 2021 nerf?
Anyone confirm anything Halloween-related yet? …or (in spite of the notes for this update) are we really expecting them to appear only after Tuesday’s server outage?
:japanese_ogre:
I’m having problems with Sterzo steering is anyone else having problems since update?
Please fix the wrong RPM indication on Zwift Companion (Android) when you do ZA 2020 Workouts. For example, on your PC Zwift says 230w @ 90rpm while on Zwift companion says 230w @ 110rpm and that you have to spinning more.
The ride leader can turn on/off the fence during rides and also change the time interval already.
Refundant
Literally while pairing? Do you have any issues when you do have it paired? I’m using an Apple TV and the companion app, and the Apple Watch HR reading drops out an unacceptable amount of times.
Propper Race in Meet up??? When
Yes, please. This is such a buzzkill.
Does anyone know the motivation or logic for keeping this broken?
It’s more complex than they thought it would be and causes too many bugs.
Tell me more about the halloween surprises please-do we get a dinosaur costume again? I love these little fun add ons :dragon_face:
It looks like this update also brought back the ‘two option’ on-screen pop-ups at intersections. I’m glad to see this come back. I wasn’t a fan of the ‘single option, press the arrow to select the other one’ set-up. The two option pop up is much more clear.
In a meet up? - I haven’t seen the ability to do that as Meetup leader.
With many of the updates over the past year, immediately after the update the mini map (using ATV) will change to the ‘angled perspective’ view, which I love. Then, generally a few days to a week later, it changes back to the overhead view, which I loathe. Why can’t they just either leave it on the angled perspective, or at least allow it to be changed like you can on iOS?
Thanks for the info. Why isn’t this in the release notes?
Y en zwinft companion que se indicara también el porcentaje de las pendientes
i think this is a setting that is getting reset. on desktop, you can click it to change it; not sure if there is a way to change it on atv?
