Game Update 1.56 [January 2024]
Is it possible to declutter your garage? I have so many items for jersey, socks hats etc cannot see my favourite ones i use.
Hi, make sure you have the cellular data option turned off on your phone for companion app. Took me years to figure that out :slight_smile: after reading about it in a forum. That might be your issue as well.
Also the Campanion app still has a lot of let’s call it ā€œtime out issuesā€ where written text messages will not be posted hence displayed in zwift chat. Been having that for years as well.
Ride on!
Exactly! Why does Zwift not enable automaticly i’m sure a lot of users stumble into this.
Wow some people really demand the world here.
Keep up the great work Zwift, ride on!
Is there any solution for this problem?
Would be great if you could make it simpler to login to Zwift for homes with multiple accounts on the same computer. Thanks for great system!
Couldn’t agree more, though I’ll add that I need a screenshot of my power trace from the ride report screen. Which should be automagic. Just finished a ride and the only screenshot I took was my power trace and it was ā€œX IGNOREDā€ by default. I think it took me 15 clicks to get out of Zwift ending my ride today.
I second this. If i could favorite 5 or 6 jerseys that appear on top of all others it would be nice.
How about the ability to disable the streak screen?
Anything idea when the promised update to Apple Watch functionality as a heart rate sensor for Zwift will be released? My boobies are getting chafed due to having to use a HR chest strap. :tired_face::tired_face::tired_face:
What??? What’s the point of climbing? It’s the thrill of the descent, right? :wink:
I’m winking, but also serious. Climbing makes me stronger, but the reward (flying down a steep descent) keeps me going; I cross my fingers for an Aero Helmet as I approach the top.
Point being, Feathers aren’t better than Aero Helmets, even on the way up. I don’t much mind eliminating the Draft Van (except maybe for group climbing portal events. Do those exist?)
Personally I’d prefer a feather to an aero powerup on the climb portal every time except the last gate. Going down is pretty fast with or without an aero powerup, and an aero powerup only lasts a short amount of the downhill anyhow, would rather it help on the uphill. I mean, maybe they should add an aero power-up on the last gate but keep them out of all the others?
Or, and hear me out here…
Aero powerup at every gate on the way down.
Ha, I mean I’d be ok if they actually showed the numbered gates on the way down even if they didn’t give any power up. It’s hard to tell how close you are at the bottom and it would break up the monotony of the descent.
I have requested that the stars return to numbers on the descent many times here.
Bonjour, Je ne comprends pas avec le prix que nous payons, l’abonnement que cela ne soit pas traduit en franƧais! MalgrĆ© plusieurs mises Ć  jour et des annĆ©es de fonctionnement, nous nous retrouvons avec des phrases en anglais pendant les entraĆ®nements qui ne veulent rien dire quand on ne parle pas anglais! Pouvez-vous faire le nĆ©cessaire ? Merci d’avance
Takes a while to install the update… consider doing that at the end of your session, surely not 5min before training
  1. The launcher can run in the background and update automatically
  2. The launcher has an option to postpone updates until after your ride
  3. If it takes more than about a minute to update Zwift there’s a problem on your end
I only care about the big XP bonus (500 for me), happy to throw away the feather power up on climb portal.
Repeated laps of climb portal at low cadence are definitely helping my strength.
I’m using this Version 1.56 of the game with a Wattbike, on a Samsung Tablet (Android) rather than the Windows laptop I’d previously used. The gear I’m in is no longer displayed , nor is the scrolling band at the bottom of the screen showing power levels expended. Is this as a result of the update or is it a known limitation with Android devices?
