FTP retest
I just finished the 6 week FTP Builder. Looking for advice on when I should retest. I hate to retest in the middle of the week because I’m usually zapped after work.
Thank you
I assume that testing at the end of the week would be fine, given that the workouts are flexible enough to take the 4 workouts on days that suit you during the week.
I’m doing the 6 week FTP builder myself - would be interesting to hear your FTP % increase, because I’m excited to see what mine will be!
Alex that’s what I was thinking. I’ll update this post after I retest.
Hi guys,
Also just completed the 6 weeks builder last sunday. I’m definitely doing an FTP test this week, so I’ll come here to post the percentage in increase, but I must state my previous FTP was months ago (sometime in June, I think)… yet it all felt pretty much still spot on with my perceive exertion & HR.
On a side note, it was my first plan and I expected a bit of a “tututututuuuu you just finished your training plan” kinda celebratory moment. I have not zwifted since, so maybe that’ll happen next time I connect.
Ride on.
Hi Adrien,
I forgot to update the results of my test. My first test was 231 FTP after my retest I increased to 247 FTP. Not quite sure if that is conciderable but I’ll take it. Trying to figure out where to go from here.
It’s a 6.9% increase, which is significant - as long as your trainer or power meter accuracy is good. (Some are still only rated at +/- 5%).
Hey guys.
Did the test on Friday eve. Went from 229 to 252. Pretty happy, was aiming for the 250 mark. Quite a good increase too, but as indicated before it may not just be due to the plan only as my last FTP was some 6 months.
Did you guys just jump right into the ftp test or did you do any specific warmups before hand?
I was trying to decide if I should do some active recovery days before hand or even try and do the 8th week of the 8wk Race Day Prep which has 2 short ‘Taper Intervals’ and a Pre-Race day spin.
Just curious, I’ve put a lot of work into the last 6 weeks and hoping to make the most of that work.
