Hi there - re the 10-12 week FTP builder.
I’ve done 5 workouts from the Compaion app and am in my second week. Anyone know how the Companion app is able to show more workouts? I can see the Weeks on the Zwift main app when logged in but nothing seems to progress on the Companion app. Any help greatly appreciated?
Hi @Nick_Bradbury1, welcome to Forums! I’m Francisco from Zwift Support.
Great to hear you’re working through the FTP Builder plan! The main app and the Companion app can be shown up differently in the (UI).
Zwift only unlocks a set number of workouts at a time to keep you on track with the plan. The main app will show your full progress, but the Companion app sometimes displays upcoming workouts until they’re actually available.
If workouts aren’t showing as completed in the Companion app, try logging out of both Zwift and the Companion app, then log back in. This often forces a sync and updates your progress.
Make sure you’re running the latest version of the Zwift main app and Companion app, as updates sometimes fix display issues.
If you’re still having trouble, you can always check your full workout schedule in the main Zwift app under the Training Plan section. Hope that helps!
Hi there
I don’t seem to be able to sign up to the plan even in the main app. At the moment I select a
Workout from each week as I work through the plan. Is this correct to have to select it daily ? If so how does Zwift know u am doing the FTP plan ?
Nick
