Floor Mat for Bike Trainer
What floor mat do you use for your bike and trainer? I have a wahoo mat and it is ok, but it tends to bunch up in the middle under my bike and I am not that happy with it for what it cost.
Do you have any better suggestions?
Thank you!
I use a Kinetic trainer mat and have been happy with it, though I’d guess it’s similar to the Wahoo mat. On what type of surface are you using it?
I use the Wahoo mat, but it hasn’t ever bunched up. It’s sitting on a rug though, so maybe it’s different on different surfaces?
Mine bunches up too. I have it on a tile floor that’s probably fairly slippery but yeah it is annoying having to pull it tight at least once a day. I was expecting it to be actual rubber not yoga mat foam rubber
Plant X mat here. Thick, well padded, probably helps deaden noise in a flat. Mine’s on carpet on a concrete garage floor. Moves a little on the carpet over time, but only like an inch and you wouldn’t notice while riding. Certainly doesn’t bunch up.
I use this one. It’s quite stiff. Seems overpriced for a piece of plastic but it works.
Also, any time you are unhappy with a Wahoo product, contact them. Their support is generally good.
I use the heavy floor mats / tiles intended for gyms. They don’t move about and they also prevent vibration going through the floor (quieter).
I got those from the local hardware store.
Rubber gym mat off Ebay £45
I use a Wahoo mat too, on a laminate floor. No bunching up in the middle.
