Tried the old launcher?
No Dave, unfortunately I donât have a copy of the old launcherâŚ
Wow youâd think they would have fixed that by now?
Check your PMs.
Having the same issue. Went away after update before most recent. Now itâs back after todayâs update. Know how I can find the old launcher and install it?
See your PMs.
Is there a fix yet? Itâs been months!
Capping fps to 60 seems to help (still flickers but less intense).
Theyâd need to acknowledge thereâs even a problem before there could be a fix.
Just roll back the launcher.
Yes - Ignore the problem and hope it goes away!
Thanks - any links/instructions on this one?
See your PMs.
Thanks buddy that worked a treat! Back up to high-refresh 120fps with 0 flickering ![]()
Will this workaround still work next time thereâs a game udpate? Will I need to downgrade again?
Game updates happen independently to the launcher, youâll get them as normal.
I am not affected by this but it seems crazy to me.
Someone says they have this issue, you send them the old launcher and it fixes the issue and Zwift seem to deny there is an issue or that this fixes it.
What are the benefits of the new launcher? why not just roll it back to the old one?
As I understand it, the current version of the installer (I keep calling it the launcher) has the following major changes over historic versions:
- Includes at least one C++ redistributable package which improves Bluetooth connectivity on first install - there was a big thread on here where someone figured out the problem of Zwift saying there was no Bluetooth device installed; the newer installer attempts to address that natively by bundling the necessary package. This is why the filesize of zwiftsetup.exe is much larger than it used to be.
- Addresses a security concern with the Internet Explorer login by updating TLS support.
- Allows for multi-threaded extraction of game updates, supposedly to improve install/update times.
None of which should affect in-game performance, but I believe the last one of those fundamentally changes something, because in my testing itâs patcher.dll (one of the files that change depending on the installer version used) which seems to be the problematic one. All the others can be manually copied back and forth with no impact, including the C++ stuff.
Also worth noting that the launcher never used to check or update itself, but nowadays it does (though the prompt can be ignored). So I expect the vast majority of people are using the latest version. As will virtually everyone whoâs installed Zwift from scratch since December.
However, aside from the stuttering it also introduces - which I can see at all times - the flickering only shows up at high frame rates. Most people will be using a TV or other 60Hz display and so by default Zwift will be capped at 60fps by vsync, hence why there arenât that many complaints about this. The problems are only relevant if youâre bothered about smoothness and/or using a setup which produces high frame rates. I fall into both camps.
yep - that is my set up so likely why i donât see it.
zwift must test stuff at higher rates though?
chuckles
Thanks, worked like a charm!
Got this on my system now, since I canât use 1.0.50 any more.
This is at stock settings, so without even disabling vsync (which forces it to appear a lot more often). My GPU and monitor are now worthless for running this game, since high frame rates are penalised and adaptive sync isnât smooth, which is the whole point of it. Streamable Video
