We won’t be able to correct the results I’m afraid. Because Zwiftpower doesn’t know the event finished, it isn’t able to give a finish time.
I think once I get an exact distance for the event I’m going to have to daily correct events using that route to the exact distance until the issue is fixed. You can bet that I will chasing for a speedy fix!
Is this issue sorted? This course is due to be used for ZRL playoffs tonight and it seems there were still issues in a race some of our team did on the course yesterday with riders missing from Zwiftpower but also finishing the event but not showing in results on ZCA.
FRR did the flash tour test event a couple weekends ago for ITT for stage 1 and FRR had to use data from strava for stage results as zwiftpower was worthless with many racers were not counted. Hope WTRL has work around or there is going lots of emails coming there way.
The WTRL/ZRL event is definitely set to the correct distance.
The event organiser (I think they have been told) needs to set that route to distance based. I always correct the ones that I see but I don’t see them all.
Sweatfest series went there yesterday and whilst the early event was configured correctly the 2nd wasnt - didnt impact my race but the 2nd race and therefore overall points are screwed. C’mon Zwift at least put an auto-routine in the events system to pick this route up and adjust accordingly. This shouldn’t be update to organisers to sort, specially after 10 months of knowing about it.
