For me, one of the main advantages of using Zwift is that I have interesting scenery to look at whilst cycling indoors and going nowhere. However the UI - especially when doing a workout - is positioned in a way that hides most of that scenery. In fact if you take a typical workout screen the vast majority of the screen that isn’t covered-up by “nearby riders”, “min-map”, “workout intervals” and the main numbers is just a patch of boring tarmac! I would personally prefer that the numbers are at the bottom of the screen so you can see more of the environment although I appreciate that this would be a big change. So ideally, you would introduce configuration options in the settings where you could choose:
1). Where to dock the numbers (top or bottom)
2). Whether to display the mini map
3). Whether to display nearby riders
A post was merged into an existing topic: HUD Customisation
A vote has been moved.
