Exit Portal at Top of Climb
The name says it all. The loop at top of each climb portal should be slightly expanded, the default turn direction should be to stay in the loop, and there should be an exit only portal at the top of the climb.
That way, if I am still feeling fresh, I have the option to exit the climb portal and hit the volcano to keep going. No need to descent the whole climb just to re-enter Watopia.
Hi @Brandon_Acco, welcome to the forums! I’m Francisco from Zwift Support
Thanks for dropping this suggestion—totally get where you’re coming from!
That idea of having a loop at the top with an exit portal sounds practical, especially for folks who want to keep rolling after crushing a climb. Right now, the climb portals are designed to be pretty self-contained, but it’d be awesome to have that kind of flexibility without needing to descend the whole thing just to rejoin Watopia.
You’re not the first to think of this, and it’s a cool concept.
Ride On.
