Error code Z117 at line 616 when updating to v1.123
Hey Zwift,
I cannot update from v1.123 (Windows 11)
The bug with special characters in account name has returned. In this this case the letter Ä (ASCII code 196).
Even if I change the admin account name - the folder (where Zwift installs stuff in users) will still carry the old name.
I do not want to have to change the name of the folder, thus totally re-arranging the infrastructure and having to go into the Windows registry.
Yes - I have read the support page, and yes setting up a separate admin account works, but I do not want to have to set up a separate admin account just to run Zwift.
Since this has worked fine for previous builds last 2-3 years could you perhaps fix this?
Cheers! /Mike
Exactly the same issue here
Probably the same issue as this one
not sure that create a new account to use the first one is a good solution. :thinking:
It’s not a solution. It’s a workaround so you can ride.
Also just to be clear, we’re talking about a new Windows account, not a new Zwift account. Make a Windows account that has no diacritics in the user name.
Hey @Jerome_BRISSET and @6_Michael_Forsman_V - I will DM you with an option that might help.
Please also DM me. Same problem over here ;-(
Hello, please give me the option too.
Mirko
Hi, please give me the option too.
Thanks, Zsolt
I’ve DM’d everyone on this thread. We’re working on a release to fix this and a couple of you have confirmed the fix. I expect the updated version to be available for download this coming week.
I also have this issue, can you dm me too? Why not post it in the thread instead so everybody can try the fix?
Hi, same issue here, i can`t start anything anymore.
We’ve published a new version of Launcher that should fix this. Please let us know if you continue to have problems:
https://forums.zwift.com/t/zwift-launcher-for-windows-macos-october-2026/671979
