Ηello long enough the application does not respond to the computer (window 10) shows me a message that can not find folder to store… what may be to blame and what I need to do for the app to work again…
welcome to the forum.
I assume you are on a work computer and don’t have access to the documents folder.
@PANAGIOTIS_PAVLIDIS
I’m having same issue, have you solve this issue?
is it a work computer?
Worth trying to see if you can browse to the documents folder on your computer to see if you can access it and create files there.
I faced the same issue and spent entire Saturday to solve it.
Right click “Documents” folder in the left pane in Explorer and fix the location to the default like “c:\users\xxxxx\Documents”,
In case if you have problem in changing location to the default then, Google “Operation to change a personal folder location fails in Windows”
Look at the microsoft aritcle and change “personal” to the default in registory editor.
Hope your problem gone by this. I think this will exclude Documents folder from onedrive sync. I’ve already stopped it first then no problem.
