Here is the information requested in the other thread. Please advise if there is other information that will assist.
Trainer Model Justo 2
Trainer Firmware version 37 hw ver1
Confirm if you are using Zwift Click, Play, or Ride. I have Click and Play both connected.
Confirm Firmware version of the Zwift shifting device you are using. Play: fw 2.0.1 hw 8.0 linked Click fw 1.2.0 hw 8.0 linked
Confirm which platforms: Windows laptop an older MSI steel series Win11, Galaxy Tab A (8.0", 2019)tablet for Companion. Bluetooth is usually off on the tablet unless I need it.
Confirm if you are experiencing the issue with: Native bluetooth for CORE, Play, Click, Rizer steering, and resistance. Direct connect/wifi for power and cadence(crank arm sensor using Justo2 bridge). I have tried via Companion(worked similar, PC seems to have a better radio), also have tried a few Dongles on USB extensions with mixed results as some of the newest version 5 ones seem to support less concurrent game devices. In general the PC radio is rock solid except for when resistance acts up. Even when resistance acts up the other bluetooth devices remain connected.
I experience the resistance disconnects after no pedaling. It might be after coasting down a hill for 15 seconds(less common), or being off the bike to grab something, or coasting down a long hill (but other times I can coast down a climb portal without any problem)
Confirm if you are using Virtual Shifting with Zwift Click, Play, (both)
Confirm your in-game Trainer Difficulty setting: 100%
Confirm your in-game Shift Style and Gear Range settings: sequential, mixed
If using Virtual Shifting on a normal bike (not Zwift Ride), please confirm your front chainring size: 39 back: 11 - 42 cogset which has saved my ride a few times after VS stopped working. Shifts rough so I prefer VS.
Notes: A couple weeks ago when I came back to indoor for the TdF event after riding outside for a couple months VS was basically unusable, no resistance changes, low resistance, worst trouble connecting I think I have ever had on resistance(bluetooth) also on power and cadence (wired/wifi?). I noticed the cadence seemed to respond weirdly. Then I realized I didn’t get cadence pedaling backward which I should with the crankarm mounted sensor. Stopped midride. Checked and found the battery was dead. Replaced and installed. Now getting cadence backward, and resistance started changing. riding. Thought that had solved it but have still had issues with lack of response since then. The 2032 battery in the sensor was down to 1v so the displayed cadence must have been from the Justo2 internal being used since the bridged device signal was absent.
Lack of response means start the ride, have resistance that might be right for gear 8, but I can change up and down 1 to 24 and back with no change in physical resistance. Sometimes seems like resistance changes at the next incline change. The change in resistance sometimes seems to reflect what the current gear number is more than the change in slope. For example the resistance has not changed since the ride started or has stopped changing mid ride. I shift down several gears. At the next hill the resistance gets lower. It may then get harder but this is not consistently true.
The Rizer will behave incorrectly as well perhaps mirroring the resistance errors, seeming to be responding in a delayed way to terrain already passed over.
A couple times when the resistance was not responding at the beginning of a ride spinning the trainer as fast as I could and letting it coast down seemed to get resistance to respond. I don’t believe this always fixes it.
I tried the circumference value change “trick” which I assume resets something. I think it might have worked on the following ride but I do not know it that was a coincidence. Certainly has not cured the problem.
