Elite Direct Connect Not Working on Sequoia
I picked up a new Elite Justo 2 a couple weeks ago along with a Mac Mini M4. Prior to a Sequioa update, Zwift had been finding the Elite Justo 2 over WiFi, but I wasn’t getting any Power or Cadence data in Zwift. It seems that after either a Zwift or Sequoia update, I can’t get a direct connection either through WiFi or using the Elite direct connection cable. I tried Zwift on iPadOS, and I can get a direction connection there. I checked the Security settings on the Mac Mini, and allowing Zwift to find devices over LAN is enabled.d
I wonder if disabling that permission and reenabling it would help here, as it has done for people using Sequoia and trying to get Companion to connect to Zwift on the Mac.
Thanks for the suggestion. I tried a couple different solutions today. I uninstalled Zwift, restarted, and then re-installed. I enabled the LAN other devices. Zwift wouldn’t find the Justo. I then turned off the LAN other devices setting, restarted, turned it back on, restarted, and then ran Zwift. It still won’t find the Justo. Zwift on iPadOS finds the Justo over WiFi or if it’s connected directly to the router via ethernet/Direct Connect dongle.
I’m not sure exactly what action fixed my issue, but I have been able to get Direct Connect to work over WiFi. Mid-ride yesterday, I disconnected all sensors from Zwift and then turned off the 10 Hz fast data on the Justo 2 in the Elite app. I also did not reconnect the Rizer as a steerer. Zwift then recognized the Direct Connect WiFi connection. I tried it again this morning on a new Zwift session, and it appears to be working for now.
Yes, it seems like the 10 Hz fast data option does not allow the WiFi connection to work. After disabling it, it also works for me. But not sure if this is intended or if 10 Hz fast data should also be able to work over WiFi
Mine stopped working after the last Zwift update. Is yours working? I can’t get the Companion App working either so it appears to be a network device issue on Mac. But, I’ve changed that setting multiple times with no success.
