Dual recording power and Transparency
Double checking Powermeter will be fun read this:
https://www.researchgate.net/publication/8474185_Accuracy_of_SRM_and_Power_Tap_Power_Monitoring_Systems_for_Bicycling
Although manufacturers of bicycle power monitoring devices SRM and Power Tap (PT) claim accuracy to within 2.5%, there are limited scientific data available in support. The purpose of this investigation was to assess the accuracy of SRM and PT under different conditions. : First, 19 SRM were calibrated, raced for 11 months, and retested using a dynamic CALRIG (50-1000 W at 100 rpm). Second, using the same procedure, five PT were repeat tested on alternate days. Third, the most accurate SRM and PT were tested for the influence of cadence (60, 80, 100, 120 rpm), temperature (8 and 21 degrees C) and time (1 h at ~300 W) on accuracy. Finally, the same SRM and PT were downloaded and compared after random cadence and gear surges using the CALRIG and on a training ride. : The mean error scores for SRM and PT factory calibration over a range of 50 - 1000 W were 2.3 +/- 4.9% and -2.5 +/- 0.5%, respectively. A second set of trials provided stable results for 15 calibrated SRM after 11 months (-0.8 +/- 1.7%), and follow-up testing of all PT units confirmed these findings (-2.7 +/- 0.1%). Accuracy for SRM and PT was not largely influenced by time and cadence; however, power output readings were noticeably influenced by temperature (5.2% for SRM and 8.4% for PT). During field trials, SRM average and max power were 4.8% and 7.3% lower, respectively, compared with PT. : When operated according to manufacturers instructions, both SRM and PT offer the coach, athlete, and sport scientist the ability to accurately monitor power output in the lab and the field. Calibration procedures matching performance tests (duration, power, cadence, and temperature) are, however, advised as the error associated with each unit may vary.
utter bollox
And what evidence do you have to back that up? Tests done by Zero Friction Cycling, formerly Friction Facts now owned by CeramicSpeed and others say that it is not “bollox”.
this is a massive can of worms the physics behind how a drive train operates is complex; your total watts in your list is large and can be interpreted differently by each individual that reads it. ceramaic speed are there to sell stuff so naturally they will spin it out to look good for them. general rule of thumb is a well looked after drive train should be 97 -98% effective, so for me with ftp of 250 should be seeing a loss of 5 to 7.5 watts tops; tbh i didnt read your post properly and a lot of those watt losses are duplicates of themselves. I added them all up assuming you meant 30 plus watts loss so apologies for that
I don’t think that zwift should combine the power numbers from the two meters, but rather, allow you to specify one as the primary and one as the secondary “witness” PM for proofing the modulation of the primary.
But this would be really nice if they just incorporated the ability to record from two different sources so it’s all in one place
It will be very helpful if our dual record can be uploaded automatically.
I’m very close to releasing a Windows app that will capture all relevant ANT+ and BLE sensors, Power, HRM, FEC, MO2, VO2 and data from Sauce4Zwift, and save it all in a FIT file. You can have pretty much as many sensors as you can strap onto yourself or your bike :slight_smile:
It remains to be seen what tools we can develop to analyze, for example, multiple power streams. But at least they are all recorded, and no need to merge and match for time. Any FIT tool that can look at Developer Fields will see the additional data fields.
Work in progress at HTTP://www.fitnesshrv.com
2024 bump^
support for dual recording
After yet another crash today I was going through the log and saw Zwift actually already dual records as it made many mentions in the log about large dicrepancies between poer from power meter and trainer (and it also records battery levels, why doesn’t zwift show us!)
eg
[ZwiftHardware] Large difference between power device and trainer: 203W vs. 79W
This would be really useful to see the battery level of the power meter device, if not on the main screen, somewhere in the menus.
2026 Bump - Maybe if we offer a badge for dual recording, people will want it.
I heard a rumor they were going to release an onscreen or otherwise enforced view of this. There is a lot in the log files that would make transparency easier. They can also see if people are using the trainer spoofing app for instance. Organizers asking for log files in case of disputed performance is a good opportunity though.
I posted a feature request last month Device battery power on pairing screen . So a shameless plug here to upvote so maybe it gets attention from zwift. :wink:
