DQ Tiny race 28.10.23
Hello everyone! Can someone explain me why I have a DQ in the 4th Tiny race on October 28th? I completed all 4 races. Where is the mistake?
Thank you in advance, Tina [WattFabrik]
Can you share the event ID or your rider ID? Sometimes there are problems processing the results but @Eric-Schlange-ZI can sort them out.
You’ll need to post a URL to the race in question, please, so I can take a look.
Nevermind, found it!
This is a weird one. Had another racer with it on the same date - ZwiftPower assigned the same “Result ID” to two riders, and when I DQd the one rider, it DQd both.
So I’ve un-DQd the one rider, which allows your result to stand. That’s the only way I can see to do it.
That actually seemed to be the reason! My DQ is out and the points are back.
Thank you very much Eric🙏
Thank you for help, Paul :smiling_face:
Eric, can you check mine too? It was on 11/4/23.
I met all qualifications- did all Tiny 4 races, HR monitor, was in the proper category, used a KIKR trainer, and was signed up for ZwiftPower. I’m not sure what would cause DQ other than a mistake, as mentioned above.
7:45 am (PT) - not sure how to find the Race ID. It’s the A category - zwift ID is 2909421
Fixed.
There’s some sort of processing bug happening, and I haven’t found what’s causing it yet. Sigh…
Thanks Eric!! I’m sure I speak for many out there - we appreciate what you do for us!!
Hello again Eric,
I’m sorry, I have to ask again. What happened now? Now I have a DQ in the 3rd race on 28.10.2023. My Zwift ID is
4665868
Thank you very much, Tina
