Disable Steering on Play Controllers
I’d like to be able to manually disable steering on the Play controllers because they sometimes get stuck steering all the way left. Disabling steering would allow me to continue to use them without worrying about the steering errors that disrupt races or group rides.
Hi, @Mark_Bronnimann, welcome to Forums! I’m Francisco from Zwift Support.
I get that steering issues can really throw a wrench in things if they pop up unexpectedly during a ride. Appreciate you mentioning it!
I was wondering if you performed a hard reset by pressing and holding the large Z button for 30 seconds on the affected controllers. This should restart the unit completely.​ After the controller restarts, try turning your unit on/off.
Calibrating Your Zwift Play
If this is more like a feature request rather than the Zwift Play steering itself all the time, it’s welcome as community insights are valuable.
I think the ability to disable steering manually would help in any case. I don’t seem to be the only one who has run into the issue so this feature might be useful. I’ve tried the full restart but not recalibration yet.
I have got the same issue, braking and steering left issue. The controllers have been replaced, calibrating, reset but after a few races it starts again and i am not able to resolve it. I stopped using the steering device.
If you don’t mind loosing virtual shifting as well you can simply disconnect the braking/steering/shifting part. Works fine for me: Modifying the Zwift Play controllers
