That doesn’t address the question since Trainer Difficulty has no effect on flat roads. I do not know if virtual shifting’s inbuilt calibration process at the start of each ride does anything to address this. Would be interesting to hear if it does.
Are you using the Cog? If not, and you have a regular cassette, can’t you just let the trainer calibrate when you start up, and then shift your mechanical real gear 3-4 times to an easier gear?
I have the problem other way around. Gear 24 is not enough on high speed sprints and sprints slightly downhill. I use my gravel bike and Zwift Cog. A possible fix would be to use big front chainring but this makes it way more noisy and rough. Small chainring is so smooth and I would like to keep it there.
Similar to my question/suggestion above, in your case couldn’t you just shift to the big ring temporarily for a sprint and then back again to the small when you’re done? Basically giving you an extra 3-4 larger gears for a bit? Or just shift the rear cassette to bigger gears if you want to stay in the small front ring if you need something past gear 24?
I don’t really know anything about the virtual gears, but with Wahoo trainers if you change the “wheel size” in the Wahoo app it changes the baseline 0% grade resistance the trainer uses.
Don’t forget that you can adjust the “offset” on your cog to get a better alignment with your front chain ring, which will resolve your noise issue. My old school road bike has a 3x front chain ring, so for normal riding / workouts I use the middle front ring and a cog offset of 5, then for races I use the big front ring and increase the cog offset to 10 to re-align the chain, which reduces the noise again.
In your game settings switch from synchronous gearing to the SRAM style as mentioned above and then pick between the gearing options (flat, climbing, all around) that best fits your needs. That should give you the different gearing spread that you are looking for.
Shimano ultegra di2 offers 52/36, 50/34 and 46/36 chain ring combos and 11/34 or 11/30 cassettes. So that’s what you have available irl, most people buy expensive trainers that are able to simulate steep grades of at least 15%. Why bother getting an expensive setup that tries to mimic outdoor riding if all you want to do is spin at a constant torque. You could just get a cheap spin bike without automatic resistance and hook that up to zwift, voila….
The zwift virtual shifting gear ratio range is 0.75 to 5.49. Basically a 30/40 to a 55/10. The range is bigger than any groupset available, and covers the gear ratios that both you and Ganna would use.
I do however agree that there should be a way to tweak the baseline resistance, but the main use case for that would be for people whose bike only has a small chainring, but whose trainers don’t support zwift virtual shifting. They should be able to give themselves a virtual big ring so that they’re not spinning out all the time
