I am new to zwift, and would like to be able to track my progress in excel, or similar, without having to type in a bunch of number manually every ride. I’ve looked into some of the fit file conversion tools, but most seem overly complicated for what I’d like to see. I figured, since there is a feature request forum I’d say I’d like to see some form of csv export of activity data. Heart rate, cadence, power, etc.
I’d like to see a way to get data into Google Fit, too, but that seems to be a determined effort to be the opposite of useful by google, as usual.
if you just want quick and dirty, you can drop you FIT file in here:
then use the export to CSV function.
quick question why not track your data in Strava it has a lot more info and stats than GoogleFit.
this may be an option, I have not tested it: https://support.strava.com/hc/en-us/articles/216919267-Google-Fit-Integration?mobile_site=true
Strava only syncs outdoor rides, no virtuals. The only thing I am currently running on my phone that tracks steps is google fit, so I probably just need to get something else.
Strava do sync to Zwift for virtual rides. Or do you mean only outdoor rides will go to googlefit from strava.
Right, Strava doesn’t send virtual rides to fit.
There is a workaround, but it’s a pain and has to be done for every single virtual ride you do (assuming you’ve linked Strava to Google Fit):
- Do your ride in Zwift, save and upload to Strava.
- Open Strava on your mobile (not the web version) and select the activity you’ve just done
- Edit the activity, immediately save it (no need to actually make any changes)
- Open Google Fit, refresh your Journal; your activity should now be pulled through from Strava.
Lol, I am already manually entering numbers into fit after every ride.
This would save a fair bit of time.
Odd, that worked twice, then went back to no uploads to google fit.
Not just you, appears this has stopped working for me since Friday as well. Nothing pulled through the last couple of days from my Strava virtual cycling activities (and I’ve got a couple of different strava privacy settings on those activities, so I don’t think that setting is the culprit). Hopefully it’s just a temporary blip and it’ll be back to the usual faff of a workaround soon enough!
Apologies for the double post. Having done some digging on this; Strava are aware that it’s broken, but don’t have an ETA for a fix as of yet - https://support.strava.com/hc/en-us/articles/360061558212-Strava-Activities-not-Syncing-to-Google-Fit
It’s almost like they deliberately went in and changed it so virtual rides wouldn’t sync, broke everything, then fixed it so non-virtual rides would sync.
