Hey, Does anyone know if you can connect the Nordictrack C1650 to Zwift? The treadmill has Bluetooth and WIFI.
The short answer is no, but you can use it for zwift. You can use it for zwift by using a foot pod or TreadTracker. Both of these devices will send your pace to zwift, you will have to control elevation manually. You can also use an Apple Watch for pace but it isn’t as accurate.
The nordictrack machines should have the capability but iFit, the company that produces them purposely turns off the ability in firmware so that you have to use their service.
I run on a Nordictrack X9i, if I had it to do over I would buy a different treadmill.
