Companion is frustratingly, MADDINGLY!, undependable and inconsistent.
Yes, it’s on the same WiFi. Yes, it is updated. Yes, cellular data is off for the app. Yes, it worked last night.
And then… it isn’t working.
This is not user error.
Companion needs a confirming process or menu to ensure establishment of a connection with the Zwift app independent of this turn it on and hope routine.
well I never have connection issues with companion app… so it must be something in your environment or how your home network is set up. Do you have wifi extenders “nodes” or anything like that?
ok, well you didn’t answer either of our questions or explain your home network setup, so I’ll ask again… do you have wifi extenders or anything like that at home, what are all the details of your home network setup?
Also worth trying, restart all the network equipment (unplug from power for a minute and plug back in), force your wifi router to use a specific channel instead of auto selecting (instructions on how to do this vary by equipment so check the make and model and google it).
I’ve had issues with the companion app for over a year, the network is the same, no extenders etc it used to work without a problem until one of the updates, router has been rebooted multiple times (mainly from VM having local network issues) the game runs without a problem on the same wifi and it just gives network error or rejects my login details
Ok, well, I was replying to the OP, but assuming you are asking me now (not the OP again) - yes, I have wifi extenders, Android App (last update 21.8.25, no other update available), run Zwift on PC.
When I have an issue, the game screen doesn’t show up on the Companion app- I can do everything else, including giving ride ons to other’s current Zwifting from the home screen, but the game screen on the app simply doesn’t come up, and the in game phone icon isn’t next to my rider name
I’ve been zwifting for an average of 6 hours a week since May, and for many months/years at a slightly lesser frequency, with exactly the same set up since October 2024 and zero issues, until the last Zwift game update.
After this update, two out of six rides have had issues, and on these two occasions, half an hour later, again with no changes to my setup, the App has shown the game screen (which thinking about it is weird - it’s almost like a delayed connection, because surely if I don’t have the game running, I shouldn’t have the game screen as an option?)
So my guess, based on hundreds of hours of everything working fine with my set up, and the only change being a game update last week, the chances are the game update brought about the problem.
Shut off the extenders and test the Zwift PC and Companion close enough to the router for good signal
Personally I have almost zero problems with Companion linking to the game and have never seen any changes that coincide with updates. I have a TP-Link Deco system with two nodes. This is on an iPhone 15 so I can’t speak to any differences between that and Android devices. This type of problem almost always has something to do with the network, though I’m in agreement that the auto-discovery process is fragile and there’s a steady stream of users who have problems getting it to work. It would be awesome if there were a secondary way to make that connection happen such as through static addressing.
I have to have wifi extenders as the only space I have in my house to Zwift is in a wifi dark spot - the extenders make it work, Bluetooth keeps dropping out, so has to be wifi.
Not sure how to do the node thing - will google in the morning. Like I say, frustrating thing is nothing has changed my end in nearly a year and all was fine - only twice in a week now a small issue (the game itself works fine, connects to everything, and 4/6 times the App has synced with the game, so thats mostly fine too, just not 100% as before)
Take the Zwift device and the Companion device to where your router is located. You don’t need access to the trainer. Unplug the extenders. Run Zwift and choose “just watch” from the pairing screen. If it works well in that scenario then the extenders are likely to be the problem.
There is no easy way to know if something has changed in your environment since new sources of wireless interference can appear without involving any of the devices you use to run Zwift or the Companion app. That part is just unknown. You should question the “nothing has changed” assumption since it may not be valid.
Its hardware dependant. Devices are getting updates all the time. Its obvious when it connects, you have the App open when Zwift is logging in on your PC and you get a pairing screen and then the whole home screen changes to the game screen. Never had a problem connecting but the map screen sometimes totally freezes during the ride at random and the only way to sort that is to restart the Android Samsung Galaxy A8 tablet and open the App again.
That doesn’t sound like what was being reported in this topic. If Companion disconnects from the game while you’re riding, it won’t freeze. The map will go away. I think you’re experiencing a different problem.
Probably but I also tried a Lenovo note and it had the same freeze problem. Its been a problem for years through all the Zwift and companion App updates. On 5GHz Wi-Fi with great signal strength and 100Mbps actual tested speeds so its not that.
Well it freezes. Happens at least once a week so that’s about 5 hours of riding. You can still go back to the home but returning to map its still stuck. Needs some sort of better refresh. Will see if the dashboard is still reporting data next time only just started using that. All the buttons at the bottom of the map die and so does the power up. Can potentially send someone a video of it next time if someone wants it.
OK well I will keep testing it for a couple weeks which should be > 15 hours of use. The thing that puzzles me is that I know there are a great many people running Companion on Android and not having the same experience as you, but I don’t have an explanation for that. If that were happening I think we’d be hearing it here and in a variety of other places I watch.
I would recommend that if you have to go back to the home screen after it freezes and then you hit the game again, the App does a complete map reset or maybe put in a refresh button or something to get it back to the default map view. Honestly do not know what causes it but I have to restart the whole device and open the App again to get it back working again. Restart the phone or tablet and it never fails to immediately start working again. The problem is not as bad as it used to be, its almost down to the level you can just live with it.
Update: it’s not connected the last two times, but what seemed to work was closing both Zwift and the App down, disconnecting my phone from wifi and reconnecting (which presumably reconnects to the nearby extender as suggested earlier?), starting the app then starting Zwift.
From that point on it’s worked perfectly as expected both times.
I think this is also largely in line with the two suggestions made, so I think you were both right!
