Since the last update the companion app is not showing workout details, no watts, heart rate, nothing. Nightmare to do workouts now
@ChrisP
Can you give us more context?
- Does Zwift Companion connect and can you see yourself moving on the Map during a ride?
- Are other things in ZC working during a workout, like do you see your followers giving you Ride Ons?
- After the workout’s over, are you able to see the missing watts, heart rate, etc on the my.zwift.com webpage?
I found you in Zwift Companion because your profile is public, and I can see your stats for the past three sessions. Can you see this view in ZC as well?
I can see the stats after the workout, it’s just the companion app not showing the details of the workout. In the app the map shows me moving. It’s very frustrating because I run Zwift on an iPad mini and use the companion to know what watts I should be doing
I cannot see workout screen at all in companion app. Everything else works in the app, just won’t bring up the workout screen. Yes on same network. Very frustrating
Same same… was working fine & now no map no live workout.
If you start companion is says your working out now but in tiny txt only on stat page.
Very frustrating as also run an iPad & phone to track RPM & Watts
if you are using the android app have you tried clearing the app cache?
I’m having the same problem. After last app update on my iPad, the Companion app on my iPhone will not shift to ride/workout details. I can see the summary stats once complete, but not during the ride.
It’s a networking problem at your end. Make sure Wifi Assist is turned off on your phone.
Thanks for your reply. Turns out all I needed to do was sign out of the app and sign back in. Seems to work fine now.
Still occurring, the workout tab is blank, map works. Andriod Companion, cleared cache, cleared data, logged out, same wireless network for game and companion. Nothing corrected it. Workouts not functioning in Companion, level up and use Companion, really Zwift?
