Companion App Fitness Trends Screen Not Matching Recorded Activities [Jan 2026]
known issue, lots of other posts about it, ZHQ is working on it
Same problem here. Using iOS. My “Fitness Trends” is missing some of my rides. I can see the rides in my activity, however they are missing from trends and other areas.
Anyone else had this problem. My ride yesterday on zwift is showing on my activities, has been transferred to my Strava and Garmin accounts but is not showing on my fitness trends graph. Did a ride today and this ride is on the fitness trends. Tried force stopping the app and logging out/logging in but to no avail.
yes, lots of posts about this already on the forum, known issue, ZHQ is working on a solution.
Happened to me yesterday. Ride is in my activities, transferred to my Strava and Garmin accounts but isn’t on my fitness trends.
Thanks for your message. Good to know they are looking into it. Thanks again.
Same here. Garmin activities are synchronized to the activities feed in the companion but do not show up in the stats and the weekly goal.
Good news — we’ve tracked down the issue and rolled out a fix.
Right now, we’re reprocessing a huge batch of activities to make sure everything is sorted. It’s a big job, so this could take up to 7 days to finish.
Once it’s done, all your fitness data will be back in perfect shape — including any new activities you log in the meantime.
Thanks so much for bearing with us while we get everything cleaned up. We appreciate your patience.
The fitness trends have been broken for a few days
Thanks so much for the update!
I’m having the same issue with my ride today
Previously I had no issues with my IRL rides that were recorded on a Wahoo Elemnt syncing with my Zwift companion. Came home from my ride today and the ride shows up on my Wahoo account but isn’t syncing with ZC. I disconnected and reconnected on the ZC and nope… still not working. Help!
Thanks.
Possibly related: they are working through a processing backlog for the fitness trends feature as discussed over here…
Gotcha. Thanks for the update. Hopefully it will all be sorted in due time. Not sure if others are also having the same issue I am…
Hi Katheryn. I can see your external ride from 28th on our system so it’s definately synced. Can you clarify that you just don’t see the external XP (the little sun icon and ride stats) on the ZC home page but you can see the activity if you view Activities>Just Me? If so - that sounds like the issue we have just fixed which Paul kindly referenced above.
Peter having the same issue from a ride today, see screen shots from Companion App and Wahoo
I just looked in Activities and it’s logged there, but not represented in Fitness Trends like it usually does
Yes, I see the outdoor ride listed in my activities but not reflected in my Fitness Trends on the ZC home page. Whew. Thanks. :slight_smile:
Hi @Marc_Snoddy_DINOS - Yes this is the same issue we identified and fixed. The update is processing now and you’ll see it resolved in the next 7 days. Same for you @Katheryn_Curi
Heres the original forum thread again Companion App Fitness Trends Screen Not Matching Recorded Activities [Jan 2026] - #38 by Paul_Forman
