I have a question how to connect ZWIFTA with the Fenix 5S watch?
I also have the HRM-Tri wristband
Why do you want to connect Zwift to your Fenix?
Zwift has to be run on a PC, iPad (or similar) or Apple TV device. You trainer then connects to that device via ant+ or Bluetooth. I think you can broadcast your HR from your fenix to that device, but it wouldn’t be necessary if you’re using a dedicated HRM.
Paul.
Hi!
I would like to have a heart rate measurement in zwift. I only have a garmin and 5x phoenix armband and I don’t know how to fasten it. is it possible without the ant + transmitter?
What are you running Zwift on?
Looking on here, it only refers to broadcasting on ant+:
https://www8.garmin.com/manuals/webhelp/fenix5/EN-US/GUID-D8D363C2-0690-48D4-95E2-A3557E7D53C2.html
So if you are using bluetooth only devices for Zwift it might be a problem.
You can broadcast the HR, but wrist HR is considered less accurate/reliable than the chest strap.
