The link to Col de Aravis goes through France to Tourmalet. So no way to ride Climb of the Week.
I think @Rowdy has already heard about this and started an investigation. It’s possible that if you restart the game and select climb of the week, you might get to the right place. Give that a try if you can.
I did the Climb of the Week today, I had no problems.
My understanding is that it can be affected by a prior activity without restarting the game. Did you go straight into the portal climb after launching the game?
Yep, thats what I did.
I did climb of the week this morning. Cirque du Suffer, then ended route. Joined through main screen route/climb of the week and no issues.
Glad we found a solution…to logout after riding in France before selecting climb of the week, At least until an update can fix this issue.
That’s not the issue. The same problem was reported on Facebook days ago.
No I did the Casse Pattes before, trying the log out/in method next time.
Thanks for the answers, ride on!
Hello all,
I’ve only seen a couple of reports of this, but the behavior that causes it seems the same:
- Do an activity in France
- Return to the home screen, but don’t log out
- Select the climb of the week and start a second activity
In this scenario, the climb portal road that loaded in from the first activity stays available on the other side of the portal and isn’t overwritten by the climb of the week. As a workaround for now, this can be avoided if you log out between the two activities before selecting the climb of the week activity.
I’ve flagged this up to our engineers to address in a future update.
