When you visit the Zwift feed page to review your workouts, do you ever wish you could just download the data to a spreadsheet?
I created an extension for the Chrome browser that lets you do just that. After you install the extension (and pin it to your toolbar), you can just click the icon to start it up. It scrolls in all of your workouts (which will take a minute or two if you have a lot), and then it presents a table containing the top-level workout data (distance, time, calories, etc) for each ride. You can click a button to copy the table to the clipboard, and then paste it into your favorite spreadsheet app.
Give it a try, and reply here to let me know how it worked for you. It’s totally free and does not ask for any personal information. The extension is available from the Chrome Web Store. Just go to the Extensions section and search for “Zwift Feed Scraper”.
Sounds a great idea, however I normally analyse my ride data either in stage or Garmin connect
Hi Freddie,
it is a good idea, in particula for those who are not registered to ZwiftPower;
anyway, I can see that, in this moment, It does not work,
maybe because that extension points to (I must put blanks, because I can’t include urls)
www . zwift . com / feed
but when we click the link, Zwift redirect to
www . zwift . com / eu / feed
so, I suppose, the extension does not recognize the url;
thank you
Nicola
Nicola,
Thanks for your message. I quit Zwift over a year ago, so I have no means to test the extension. I was unaware of the redirect you described. Apparently, it still works in North America—still being used according to Google. I will take a look and see if I can make a quick fix.
-fh
Hey Freddie,
wow, infact If I change “country or region” and I choose US,
it starts to work, I can see the rider pedalling in the dialog window;
but the rider keeps pedalling; I will launch this function at night;
thank you
Nicola
When it works correctly, the feed will scroll down all the way to your first recorded ride. This is done to enable scraping all the data. You should see the scroll bar (elevator) on the right of the window start moving down if it works correctly. As I noted, I haven’t actually used it in over a year.
-fh
Ok,
it seems that it is necessary to manually go to the
tab ‘my feed’ | sub-tab ‘just me’;
then call your extension and it starts scrolling and then proposes the result;
so I downloaded my 429 races/rides/activities;
thanks
Freddie (and nicola), thanks for posting, and thanks Freddie for creating the extension. This just worked for me. One question for your Freddie, if you ever read this post - would you share your extension code? I would like to get the name of the ride event that I participated in.
The code is on GitHub. I can’t post links here. The public repo is named zFeedScraper.
Freddie,
Thank so much for your prompt reply. I will take a look.
And thanks again for helping me save/recover nearly 8 years of Zwift rides easily! I use an AppleTV for Zwift and it does not keep any of the Zwift FIT files locally.
The alternative (as you may remember) is to manually scroll through the Zwift feed online. Tedious!
Regards,
Mark.
Freddie,
Just following up with another thanks
I am not a developer, so writing something like your zFeedScraper Chrome extension from scratch would have been impossible for me to do.
Having the foundation kindly provided by you has allowed me to extract the Activity Title field into the table. Some tidying up and formatting is needed, but it’s working. The Chrome developer mode was useful.
Cheers!
Mark.
