I’m having trouble mounting my canyon bike on my hometrainer. Once installed, the cassette is stuck and won’t turn. There’s also a problem with the fork tips who are in contact with the hometrainer.
When fitting the cassette to the wahoo kickr core, I left all the spacers in the same place on the hometrainer (there are 5 or 6 of them).
In short, do you think there’s a compatibility problem between my bike and the hometrainer? If not, what would be the best solution (simplicity), install a new cassette on the HT and leave the bike’s native cassette in place with its spacers in the right order?
Technical details of the bike and HT :
A) Hometrainer : Wahoo Kickr Core (2021 version)
B) Bike : Ultimate CF SL 7 Di2
Front derailleur : Shimano 105 Di2 RD-R7150 12s
Rear derailleur: Shimano 105 Di2 FD-R7150
Cassette: Shimano 105 R7100, 12-speed, 11-34T; Number of sprockets: 12, Range: 11-34
Thru Axle : Axle size: 12x100 mm & Axle size: 12x142 mm
As others have noted - Wahoo has made some modifications to some of their KICKR trainer axle adapter ends which may or may not help improve interference with your specific frame. It’s worth looking at the adapters you have to identify which is on your trainer.
