Cadence Kickr Snap, Apple TV
Can anyone confirm that they revive a cadence read out from their Kickr snap when using the Apple TV app? I’ve tried to reload and reset everything, even attempted firmware update on Kickr but still no cadence ??
The issue you’ll have with the ATV and trainers without built-in cadence is the ATV doesn’t have enough BLE channels to connect to an external cadence (pod-type) sensor - you’d need to use Companion App sensor bridging or some other bridge. (NPE-CABLE pod or similar)
Thank you, makes perfect sense now.
