Sounds beyond my ability.
hopefully someone is looking at it but not sure they are.
@shooj - is anyone looking in to this/ just so i can manage my own expectations.
It has been confirmed by a number of people on different set ups and a potential cause has been identified so looks like it is game related.
If you use Windows you can try this to test
what do I do with it? (basic terms iâm afraid!)
Replace the executable in C:\Program Files (x86)\Zwift (backup the original first to restore it later).
This is not a fix, the patch just disables the feature where I suspect the bug was introduced.
will give it a go and test it this evening.
thanks for your help on this, much appreciated
Yep, that fixed it. Didnât notice anything else change while riding so hopefully could be a quick fix.
Thanks so much, watopia is back on my route selections
So itâs confirmed the bug was introduced in game_1_28_ftms_road_grade_lookahead_time_exposed
. I guess they could just disable that feature (server side, no client update required) until the bug is fixed, since it seems to be causing more harm than good.
do you know what it is meant to do?
I didnât notice anything different in game so didnât notice anything not happening as a result.
Given the feature name (road grade lookahead) I suppose its intention is to make the resistance change smoother by looking the road slope beforehand. It only applies to trainers which support FTMS, that explains why the bug doesnât appear for ANT users or BLE trainers which use proprietary protocol.
Did a few laps of the beach island route this morning and that all went fine too. Previously a few of the turns here would have had the resistance issues.
Can you reupload the data? The bug still exists in the new update. They didnât fix it
Odd, I tested yesterday after the update and it appeared to be fixed.
Thereâs an easy way to disable a feature on Windows, open ZwiftApp.exe with an hex editor (like HxD), search for the feature name (game_1_28_ftms_road_grade_lookahead_time_exposed) and change any character, then the actual feature wonât be enabled.
E.g. you can do the same with âgame_1_20_home_screenâ to have the old home back.
Thank you. First impressions are good. Iâll test it tomorrow on more routes
I know a lot of people might be interested in this!
Thereâs an option in the âviewâ (or âshowâ) menu, visible columns, yours is selected only text and mine both hex and text. But shouldnât be a problem, you just need to change a character (e.g. game_1_20_home_screen
â game_1_20!home_screen
