I have bought the Bowlfex 326 treadmill (equivalent of the 216 in u.s) it connects to Zwift perfectly for speed but the stock heart rate monitor can’t be added to it, it does not see it when you try to pair it… it definitely works as it is showing on the treadmill…
I have ordered a polar t31 as I wanted an extra one anyway… will this work or am I doing something wrong?
I am guessing that the Bowflex HRM is Bluetooth only, so when it is connected to the treadmill there is no way for it to connect to Zwift. Bluetooth only allows one connection at a time to any device or app.
Bowflex 326 uses uncoded Polar GymLink for heart rate monitoring. It’s not Bluetooth.
As Paul_Allen said above, if you want to record heart rate using Zwift you’ll need a Bluetooth HRM. Polar H10 supports coded GymLink and Bluetooth at the same time, but unfortunately the Bowflex 326 only supports uncoded.
