I have updated Zwift version to the latest and it seems some objects in the world are not working, instead black masking is shown on them. Also I get some flickering black squares around other players when attending events. My setup:
This is the first I’ve heard of this issue. Do you have any screenshots as an example?
What screen mode settings do you have set for Zwift – Full Screen or Windowed view? Have you tried swapping between either of the two settings and does the graphical issue happen regardless of which view you have set?
Yes, in addition to deleting the app itself, I also removed the files from Library/Application Support folder and re-install did the trick. Thank you for your help!
