I use a LifeFitness T3, but with an older console, so connection only works via the Stryde Live footpod. In this way, I use the T3 as a regular treadmill for running in Zwift and it works fine.
My question is, at which incline should I place the T3 to have a realistic output of power when running? Is it 0%? Maybe 2.5%? Which is most accurate, comparing running ‘outside’?
I was always told that you needed to run a treadmill at 1% to reflect real life - however when researching last week I found an article that said this wasn’t true. Just run at 0% on the flat and then increment the treadmill up in line with the %age shown on the top right hand corner mini map.
