I have my ANT dongle hard wired from the foot of my Cyclops Hammer to my PC but when I coast, if even for as little as 1 second, my avatar pulls over and stops. The delays I am experiencing are frustrating and can’t be normal.
I am running CAT 6A cable, hard wired from my modem to my PC. I have 10/2 download/upload speed.
My router is an Apple Time capsule, and I have CAT 6A cable running from the router into the computer. I was told that is the fastest data set up I could get. It doesn’t seem to matter if I can climbing or going fast or slow…
This shouldn’t have anything to do with your Internet speed. Zwift is designed to run the speed and physics calculations offline - it’s just how your position is transmitted to the rest of the world that requires a connection.
The more important questions are about what speed you’re going when you stop pedaling, if your speed/power readings are consistent or intermittent (are you getting dropouts?), how much your avatar weight is set to, and if you’re on a grade.
Paul, I will double check my upload/download speeds. Having done more rides, if I am going below 20k the avatar promptly pulls over and stops. Crazy thing is the system is “so” responsive to when I coast but not really into when I start pedaling again. I pedal for 20-40 seconds before the avatar starts moving again!
