ATV crash when starting a workout [Sept 2025]
I zwift with Apple TV and It crashes frequently. Can you help me?
Check if these reports look familiar to you:
You should also make sure to force quit the Zwift app on Apple TV after every activity and see if that helps.
I have also reinstalled It. The constant Is that of I want to start directly with a training Plan It crashes. The only way to avoid It Is to start without any Plan and only After to set the Plan.
@Berto
Are these stock training plans that come with Zwift? Or custom workouts that you’re importing into Zwift?
Stock ones
@Berto
At this point, please contact my Support Team colleagues so they can provide one-on-one assistance and dig into your situation.
I’ve looked through your recent server logs and see you’ve done the Tabata Time Lite workout from the New Workouts collection, is that the one that’s been giving you trouble? Please let my colleagues know the exact steps you took to get there from the Home Screen, and include the route you chose to do the workout before it crashed.
I selected Tabata Time Lite from my Apple TV and was not able to reproduce the crash. One data point doesn’t prove anything, so it’s possible the crash isn’t caused by that specific workout, but by something else.
Last thing - when’s the last time you rebooted your Apple TV box? Not put to sleep and woke up, but actually unplugged the power cable and fully powered it off / back on? Sounds silly, but give that a shot if you don’t remember the last time you did it.
Just tried 2 times with the same training Plan in watopia and It crashes. Then I selected the same training Plan but in France and It didn’t crash. Maybe Is It anything related to watopia?
@Berto
We’ve spun up an investigation. I’ll update this thread when there’s news to report.
Try to look into Tempus Fugit. It Is happened again about 1 hour ago
Happening to me as well, crash every time. Sent below to support this morning. Fresh install on a fully reset AppleTV and still crashes note: this isn’t the startup issue - I can actually join a free ride, just can do any workouts
This started about 2 months ago - I have not been able to do a single workout since (was summer here, so I went outside). EVERY time I try and launch a workout, Zwift crashes when loading Watopia (or whatever region I pick). Zwift is not leaving an .ips dump on these crashes. Note: I do have an .ips from an earlier crash (which may or may not have been when loading the workout - sometimes Zwift crashes on startup) but since I did a fresh install and restart of AppleTV, the workout crashes are not leaving .ips files.
1m video showing the problem (provided video)
My setup:
Zwift (fresh install as of today)
Apple TV HD (4th generation, 2015) running Apple TVOS 18.6 (22M84)
  • currently connected via ethernet (for debugging), was WiFi with AP 20 feet away with full line-of-sight.
    Zwift Companion running on iPhone 15 Pro iOS 26.0
    Connected via companion: Kickr Core, 4iii power meter/cadence, Polar Heart Rate monitor
